florida-sparkey
- Pinellas Park, Florida
- Master Electrician
All this for an air compressor? Hopefully this isn't something they needed in service immediately.
Sent from my iPad using Tapatalk
It is a lot for a compressor (mind you its quite a complicated one.) The unit is in place and working as we type but it has a failing / melting lug in the disconnect. When I went there to look at a simple disco swap out, I noticed it was only rated for 240 Volts. There are many other issues as well. I am tiring to re-figure everything because the original installer did not have a clue, and, do it before that disco fails. The unit runs all the air driven machines in this large manufacturing facility. Time is of the essence because if the disco fails, everything stops. I have a shut down planned for this Saturday to do the work.
Any and all input is appreciated.
