I am working on a design with 24kw SMA tripower inverters and I was told by tech support that all 24kw can be installed on one MPPT as long as the input amps is below 33A. I have worked with ABB trio inverters in the past and I believe that the total was split between the MPPTs. The issue is when you have say 5 strings @ 6kw each. If you put 3 on one side and 2 on the other is the first side going to clip down to 12kw?
