Do i have enough power to run this equipment?
bukun
New member
United States
We have a 3 Phase, 208, 100 Amps coming to our building. There is a 100 AMPS 3 Phase Circuit breaker connected at the meter.
I am monitoring my usage in real time by using this energy monitor called EyeDro. http://eyedro.com/business-electricity-monitors/. Based on the result (see the screenshot of the graph showing the usage in real time. Each phase is depicted by a different color) i am seeing that we are using roughly 7KW on each Phase during the peak hours.
So my question is - do we have enough power in the current building to add a new equipment which is asking for a 3ph, 208, 100 Amp Circuit? I don't want the main circuit breaker to trip when i power this machine. Any help will be highly appreciated. If there are any more data required, please let me know.
Thanks
If you only have 3 phase 100 amps in the building and you are adding a piece of equipment that is 100 amp 3 phase then you need a service upgrade. The monitor does not help in determining the calculated load. You need to contact an electrician
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC? Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
