EMT with an equipment ground run from an electrical panel to a disconnect, the EMT is used to ground the disconnect enclosure, the equipment ground from the electrical panel to the equipment is connected to a ground bar in the disconnect that is not bonded to the disconnect enclosure compliant or not code section please
