Aleman
- Southern Ca, USA
As my wife puts it, I'm a fountain of useless information...Have they been making these for awhile? I don't know the age of this thing but it isn't new and the controls are so minimal as to not match what I have seen on newer Italian equipment. Dang Jraef, how
did you learn all this stuff? You have seen a lot for sure. I have seen a fair amount myself but I can't seem to retain it nearly as well as you do!:dunce:
I agree, and also see the connection to the neutral to be somewhat pointless. Typical 9 lead dual voltage motors are the same thing when connected to "high" voltage except they float the neutral - but unless something is wrong current is balanced and no connection to the neutral is needed.That's a star connection disguised as a triangle.
Still looks to me like what most have been suggesting - connect the motor windings in a wye configuration and the input volts needs to be 480 volts, connect them in a delta configuration input volts needs to be 277 volts, though that would not be a standardized voltage system to have three phases @ 277 volts from each other making this unusable at that voltage without some non standardized supply equipment.View attachment 12965
One of the guys I work with had a pic of the plate and he sent it to me. An oddball it appears to be but here it is.
