I'm experiencing an issue in a home where the electrical system in the house has begun to behave erratically. The lights throughout the house are dimming and flickering at random and when various appliances are run it causes circuit breakers to open in the main electrical panel. For example sometimes when the garbage disposal is run it causes the breaker feeding the TV to open. Also the lights dim and flicker more often when the washing machine is running.
I first checked with the local utility and they’ve metered the house and the service transformer and are 100% confident it’s not their issue. There are 3 or 4 other houses fed from the same transformer that aren’t experiencing any of the same issues. I also had an electrician shut off the main breaker to the house and check the incoming voltage at the house meter and it’s balanced when there’s no load on the house. The voltage varies from anywhere between 110 volts to 130 volts on either phase when any load is brought on (microwave, hair dryer, or washing machine).
I also had the electrician check the neutral to ground bond in the main meter cabinet and he also drove a new ground rod and neither of these fixed the problems. We then tried to isolate the circuit in question by running a hair dryer at different outlets in the house and we still see voltage swings each time.
Basically I’ve run out of solutions and am wondering if there’s anything anyone can think of that might be causing the problem. It started out of the blue about a year ago and the house is about 20 years old. The electrician thinks the whole house needs to be re-wired but I don’t want to get on board with that until I know what the exact problem is.
