mgookin
- Fort Myers, FL
- Retired inspector, plans examiner & building official
Neutral behind the meter (almost) guaranteed.
The lights throughout the house are dimming and flickering at random and when various appliances are run it causes circuit breakers to open in the main electrical panel.
I also had an electrician shut off the main breaker to the house and check the incoming voltage at the house meter and it’s balanced when there’s no load on the house. The voltage varies from anywhere between 110 volts to 130 volts on either phase when any load is brought on .
I guess it depends on the power company.
I had voltage issues at my own home, I called the power company on the way into work on a Saturday. Within a couple of hours they called me back, said they had been by the house, put in a load tester, confirmed the problem and had a repair truck on the way. By noon the issue had been fixed.
I have no doubt some power companies are as bad as described just saying don't assume they all are.
