GerryB
- woodbridge, ct. USA
The HO has two lights in a dressing room controlled by 3-way touch plate switches. He said they died after a while of working where he would push the switch many times to get them to come on. I tried tying all the switch wires together and nothing, although I did see a little arc which I though I might not see if the relay was bad. He has 16 relays in a box in the basement. Would one relay be used for just two lights? Each 3way has a single pole in the plate with it for different lights that are working. Also is there an easy way to find which relay is for these lights. The bulbs are ok, I didn't take the fixtures down to see if anything came apart, but now I am thinking since I saw that arc maybe it has nothing to do with the low voltage. Thanks for any input ahead of time.
