godsquadgeek
- Western, United States
- industrial electrician for food processing facility
Most of the guys I know have one of them sliders that show the amps of motors and what entails overload, feeders, and branch GF protection fuses.
but I am starting to see some of them get outdated, and was wanting to see what the 2014 code states regarding this.
I used an Uglies, and it said a 25HP 480 continuous duty motor (with O.L.) was 50 AMPS.
even thought the FLA was only 34.
then I used an online calculator
http://www.electrician2.com/calculators/motor_ver_1.html
(based on the 2011 code the above states the fuse size at 60AMP or at 175%
both the 2014 uglies, and 2011 calculator were using dual element time delay.
so I put 50's in, as that seems to have a greater consensus.
but I was currious if the section changed between 2011 and 2014, or even 2008 to 2014.
I also used a 2008 handbook and it seemed to want to say 175% was the right ratio.
it's just that 175% seems awful high to me,
almost double.
many guys I know are uncomfortable fusing even higher than 125%
any thoughts?
almost double.
any thoughts?
