Tony S
- Resting under the Major Oak UK
Thank you! Those numbers are a life saver! :happyyes:
Then I will go with 3 phase.
Im however tempted to pick a 208 delta 600Y transformer just so I can have a mid point ground.
If I did choose 1000 volts, I would need cable other then typical THHN/THWN?
Why?
You want a single phase not three phase supply.
UK cable costs are crazy, it’s cheaper for me to buy 25mm² 4c SWA than 50mm² 2c. 4c is “off the shelf” 2c would be to order. I would double up on the cores in a smaller cable and save money. The one proviso would be, they are correctly identified at the terminations.
