- Placerville, CA, USA
- Retired PV System Designer
There is, however, an asymmetry in that one phase wire is fed from two windings in series and so has a higher source impedance and voltage drop than the other two.You can feed a three phase load, with an appropriate adjustment to the transformer capacities.
Yes, you could I suppose calm it an open wye, but it has all four wires.
