- NE Nebraska
I don't think it was all that clear if 14.8 volts was nameplate rating of the unit or what was actually measured.That's an indication of this problem waiting to happen. Why? Because that's the input voltage that the inverter is rated 1000W on. When voltage is less than that, which is common during vehicle operation, the inverter tries to put out the same wattage at lower input voltage and thus overheats. (FWIW, I've burnt up audio amps for the very same reason.)
If you replace the inverter with a brand new one, it'll likely work for awhile... then the same thing will likely happen. Try getting a 1.5 or 2kW inverter....
If 14.8 was measured it presumably was with vehicle charging system running, otherwise voltage should have been closer to 12 volts.
We also don't know (if it was measured voltage) if that was loaded or unloaded.
As iceworm pointed out 1000 watts at 12 volts is around 80 amps. One may want to look into what is there for a supply circuit and see if there is any problem with handling that kind of power over whatever distance it is connected to.
If it once worked fine but now doesn't there could be a failing connection somewhere limiting the current when it reaches certain levels, I've had this kind of troubles before with too small of conductors on only 300 watt units - they worked fine at low load levels but not at higher load levels.
