Looped Power Feed?
mbrooke
Batteries Included
United States
Technician
Tony if you have info to add please do so. If you are posting just to bust my chops that is not helping anyone.
I believe he has explained this before in a different thread. Of course I recall you did not listen much to him...
big john
Portland, ME
I submitted a PI that was rejected that would have permitted small conductors in parallel.
I fail to understand why you need a study for this. As long as the OCPD rating is equal to or less than the ampacity of the smallest conductor that is connected in parallel there is no safety hazard.
Seems like if this is a common practice for our neighbors across the pond there is already a body of regulation in place addressing the safety. You'd think reference that would be proof enough.
don_resqcapt19
Illinois
retired electrician
Maybe it would have been if I would have cited it, but I doubt it. Someone would have to pay for a fact finding report done by someone like UL for my proposal to pass, and that is not likely to happen.
romex jockey
Vermont
electrician
It’s pretty obvious you have no interest in other regulations. Wrong, correct, wrong, wrong.
Yes we do, in fact MBrooke and i have the entire BS document available
Unfortunately , you've single handedly put the boots to any civil exchange we could have had with your prejudice against American Sparks , who you openly call 'septics' on your UK forum
So here's something you can take back there for us Tony
Kiss Our Septic A**
~RJ~
Put a 40 amp load in the center of the circuit and feed both ends of the ring with its own 20 amp breaker.
Roger
That is a problem with NEC, though if you had it balanced impedance wise on each half in theory they should both draw same current. NEC wouldn't like the parallel OCPD's either unless they are a listed together as a unit.
I was trying to describe a true "ring" or "loop" with both ends originating at same 20 amp overcurrent device.
mbrooke
Batteries Included
United States
Technician
Kiss Our Septic A**
~RJ~
I am still waiting for an apology about being called a 3 world country :rant::
mbrooke
Batteries Included
United States
Technician
You are talking to a man who thinks America is a 3 world country just because we have a Constitution and different standards. Please do not take him seriously.
roger
Fl
Retired Electrician
So you think I will never find the links to the AFCI threads and Iwire will be right?
What does AFCI threads have to do with this thread? We are talking about Loop (ring) circuits, I simply asked you for a link and now you seem to be upset.
What's your real problem here?
Roger
romex jockey
Vermont
electrician
The English ring circuits debuted after WW2, engineered mainly out of lack of raw materials (CU) , summarily skimping on what would normally be a proper installation.
That their BS (aptly named) doctrine dictates 30A on the equivalent of 14AWG makes this more than evident....
what does one expect of a failed superpower?
~RJ~
mbrooke
Batteries Included
United States
Technician
Roger
No, not upset at you. Or Iwire.
mbrooke
Batteries Included
United States
Technician
~RJ~
Rings well when intact, however, its funny that the UK requires RCDs in case something goes wrong yet nothing if the ring becomes compromised. Also, rings are frequently abused by DIYs creating a number of hazards.
romex jockey
Vermont
electrician
A 'spur' off a ring is allowed by BS Mr. MBrooke, so it's clear the abuse is advocated
Thier RCD's are serve as no more than a stop gap to it all....
~RJ~
romex jockey
Vermont
electrician
Need i mention their 'consumer units' are manufactured with little more than what passes to hold hot coffee here to boot
~RJ~
mbrooke
Batteries Included
United States
Technician
~RJ~
Yes, when it feeds a single socket. DIYs will often feed many sockets in an entire room with a spur leading to 2.5 even 1.5mm2 wire protected at 32 amps.
mbrooke
Batteries Included
United States
Technician
~RJ~
Tupperware containers. Its not until recently their regs required metal consumer units where they all gripe about a long needed improvement. Wire bending space requirements are still lacking, we took care of that in 1984, even though at the time our panels still had more wire bending space then they do now.
