alive wire
- Phoenix, AZ US
Nope it is about two and a half to three inchesIs that photoshopped?
The box almost looks like it's above grade.
Waste of a nice vault
Sent from my E6782 using Tapatalk
You guys should have seen the rest of this it was done 6 weeks ago and it all looks this unprofessional and of course no permits were pulledAn upside down plastic bucket would have been more suitable.
Now you see, I knew I should have waited I was silly and bought the 2014 I should have waited for 2015 to come out. I always find myself running to catch up on new code requirementsYes, that was a change in the 2015 nec
And I didn't know romex could be directly buried in the ground
Sent from my SM-N900V using Tapatalk
That's how it was when I arrived, I couldn't resist taking a pictureI still can't stop laughing.
Was the extension cord there when you got there? Or is that something you rigged up for testing?
I don't see the problem.
After miss diagnosing the problem with the circuit three separate times and charging the customer $2,200 the customer lost confidence told him he'd find someone elseWe're they coming back to finish this. Or this was the finish product to the customer.
If all of the conductors (both phase and neutral) are grounded the circuit will be electrically as safe (and as useful) as a brick.I don't see the problem.
I see green wires. Green wires are for ground. Therefore, the circuit is grounded. With a redundant ground, 'cause there's TWO green wires.
That makes it totally safe.
Right? :huh:
