EEEC
- Benicia, CA, USA
Hello,
So I bid a job last year based on a set of drawings (they were incomplete at the time) for some friends of mine who own a dispensary here in California. I bid it based on the use of NM-B since it is only being used as a retail/office space with LED lighting and convenience outlets for phone chargers, computers, a couple fridges, cash register, etc. and it is wood framed.
Well after getting the runaround by the city for a year, they finally got an approved set of drawings, with a few changes in floor plan layout, etc., no big deal. But as I'm reading the new electrical notes, the engineer has specified that I "... must use Rigid or EMT conduit or Flex Metal Conduit (pigtails or units on direct connections or cabinets and concealed wherever possible)." Obviously this would make my price almost triple if this is the case. But I'm pretty sure this is overkill and isn't necessary.
So I know the basics like:
NM mustbe protected from elements, can not be exposed (under 8ft), etc.
MC cannot be exposed where it can be crushed, exposed to the elements, etc.
EMT can be used virtually anywhere with the proper fittings, etc.
All of these can be backed by code.
Here's what I'm confused about and can't wrap my head around:
If you look up NEC and CEC 334.10 and 334.12 it will tell you the building type in which NB can be used. I looked up the types (I, II, III, IV and V) and they only speak of fire ratings, etc., but nothing about "commercial" or "residential".
So I ask around and people say:
You can use NM for an office building if it's under XXX stories, and it's wood studs. Well I know that the "stories" is out now, and I know that you can use NM with metal studs (100% certain for residential). Doesn't seem like a good answer.
or
You have to use MC in an office building. I can't find this in the code...
I've done a lot of searching and I can't really pinpoint the answer to these questions. At least not in the the frame of reference of building use types. And I am trying to formulate a "rule of thumb" while I'm at it....
1) What/who/why determines which wire type which needs to be used with regard to building use? The engineer? The inspector? The code?
2) When do you know it's okay to use NM? When should you use MC? EMT? (We are only talking building uses here, I know the obvious code.)
3) Can anyone provide code that says you "can not" use NM on an office space?
Thanks in advance for any help with deciphering this mystery for me!
or
