What is the exact amperage on a 1.5hp, 115volt motor at 90 percent efficiency?
Sent from my SM-N900P using Tapatalk
Which is fine if they want you to exercise using that formula - they were still short on information to do it though, power factor is also important here.What answer did you come up with? Sounds like they were asking you to use the 746 watts/HP calculation.
Have you ever seen a single phase AC motor that runs at a PF of 1.0? I haven't. If it's a Shaded Pole motor, the PF could be as low as .6 and if it's a universal motor, it could be as high as .95, so without knowing what kind of motor it is, even guessing is fraught with inaccuracies.I agree the question is vague but since no power factor is given why not assume that it's 1.0?
A = kW/VxPFxEff. The test question only gave 2 out of 3 necessary factors. So whatever you come up with will be an estimate, not an exact value.
Yeah, what was I thinking. Why would someone let reality get in the way of a good test question? :roll:No, but sometimes test or practice questions are hypothetical. It doesn't say that the PF isn't 1.0 and does not give another value. The person who wrote the question had something in mind. Assuming that the PF is 1.0 makes the problem workable even if the question is poorly written.
