I asked about this rule before, and it didn't come up in the discussion that you need a support if the vertical rise is significantly less than what the table prescribes.
http://forums.mikeholt.com/showthread.php?t=173731
I don't read anything in the NEC's text, that says you need a support when the length is less than the table. Maybe I'm missing it. Intuition would tell you that when your vertical rise is just a few feet shy of the value the table prescribes, you'd probably want to have one anyway. Yet if your vertical rise is only 10 ft, you probably wouldn't even be thinking about this.
The order of the sentences gives me the impression that to require a support, first vertical rise must exceed the value in the table, and then you follow the remaining rules for how to locate the supports. So this would mean that if the table prescribes 100 ft, then a 99 ft rise wouldn't require any supports, a 100 ft on-the-dot rise would require 1 support, and a 105 ft rise would require 2 supports. Please correct me if I am wrong.
kwired gave an interesting case to think about, which makes perfect sense. If you are reducing the wire to fit the equipment in a much smaller factory terminal, the factory
lugs probably cannot withstand the weight of the upsized cable, and therefore supports should be provided even when 300.19(A) doesn't require them, to anticipate this less common situation. Even though in the general case, as he stated: .
