Markaaronky
- Lexington, KY, USA
I've noticed several comments on Mike Holt's videos about the "cute little wire" on metal light poles that Mike points out isn't necessary because of the huge metal bolts that already ground the pole. Viewers point out that this wire is (unnecessarily, because of the bolts) there to bleed off induced voltage, rather than lightning protection.
My question relates to the concept of "bleeding": regardless of how the pole is grounded, as long as it's being subject to, say, EMF, isn't it true that there is a flow of current from the pole to ground? "Bleed" means current is flowing as long as a voltage is being induced, right?
I know this seems self-evident, as in current flowing in an antenna as long as it's being hit by a radio wave. But I've run into some people who stubbornly insist (forgive me, I know this sounds bizarre) that anything--in this case, humans in particular --that's grounded isn't subjected to the effects of induced voltage. They argue that if it's grounded, no current would flow. My understanding of the physics is different: a voltage is induced on the light pole or human or whatever, and current flows to ground, until you stop inducing the voltage. Do I have this wrong?
Thanks for entertaining what must seem like a very offbeat question.
