K8MHZ
- Electrician
I was really wondering if an antenna that is not intended to be grounded would stop working if grounded. You say yes at a reduced output.
That's correct, but with a little finesse.....I could make the antenna work just fine even if the radiator was somehow DC grounded.
The length of the wire grounding the radiating element of such an antenna is critical. At varying lengths, the wire can look like either a short, an open, or a perfect match (50 ohms for my stuff) to the antenna at radio frequencies.
If done properly, an antenna could be 'grounded' with little or almost no effect. But that's not going to happen often by accident.
