The Great Sarducci
- Detroit, MI. USA
Hi,
I'm looking for some clarification on what the NEC permits as far as options to ground receptacles that are inherently ungrounded. I live in a 1941 ranch; which of course is no surprise that all of the original circuits are fed by 2-wire ungrounded romex. Although I may choose to keep some of the receptacles in my house as 2 prong ungrounded type (particularly in areas of the home unlikely to see many modern appliance applications), I do wish to convert the majority of the receptacles in the home to grounded circuits. From my previous experience in residential work; whenever a job called for this we'd usually do one of two things; A) Meet the requirement by installing GFCIs on each ungrounded circuit, or B) If the job was much more involved in updating the wiring in the home; we'd just run new 2-wire w/ ground romex to the circuits in need, and rip out the old wiring.
Now to my question; Is it considered an acceptable option according to the NEC to ground my receptacles by running individual ground wires to each circuit from the main service grounding point (Green THHN/TFFN)? I remember a while back being told by a fellow Journeyman that this was a viable option, but am not seeing anywhere in the NEC that permits it (looks more as if it's prohibited in the code). I found some information about an exception in article 303, but it seems inconclusive. Some have told me its an acceptable option, others have told me its never acceptable to ground circuits this way, and yet some others have told me that although the NEC generally prohibits running ground wires to a circuit in the case where the grounds are not contained in the same cable/raceway as the rest of the circuit, there is an exception provided when the circuit of the old work is unable to be modified without replacing the entire cable, and where this is the only means of grounding. I just need some of your opinions on this, so that I can know once and for all if I should even consider grounding my outlets this way. Rewiring the whole house isn't going to be an option for me at the moment (time & money, etc), and would really rather not resort to having to go with GFCIs everywhere in the house for the simple reasons that A) that's expensive, and B) In my opinion, unless a circuit requires a GFCI, I'd rather not have to deal with using them. To me they just tend to be a pain in the rear sometimes with nuisance tripping, bulkiness, etc.
Sorry if I'm rambling on, but would love to hear what you guys have to say.
Thanks, Ryan
Thanks, Ryan
