Buck Parrish
- NC & IN
I am installing two 225K and three 150K. 480 Delta to 120/208 Wye
There is no building steel to bond to. Water lines are plastic. Some one was telling me to install a ground rod at each one. To me that didn't seem correct.
I thought all I need at my primary is the three phases and the equipment ground. Then some body else is saying well pull a neutral and an equipment ground on the primary?.
Since each location is a newly derived electrical system. Must we isolate the grounds on the secondary disconnect / 200 amp 3 phase panel
Which is correct? Or maybe both ways are correct, or neither?
I've also been told I can adjust the 208 volts on my secondary. To a higher voltage. What are your thoughts on that?
Thanks for the help in understanding the inner windings of the transformers
Thanks
Thanks
