jerjwillelec
- Nevada, IA
- Master Electrician
A customer called and said they've been replacing an abnormal amount of (natural gas) water heaters over the last several years (2003 to present)...like every three to four years. Their plumber of course said this isn't normal and compared it to another time he found that there was current flow causing the tank to rust out and leak. He told my customer it could be the same thing. I don't necessarily disagree so I immediately went to the water main, which is not bonded to the grounding system. My thinking is that sometime before they bought the house, someone may have bonded a receptacle to a water pipe which could cause current flow. I told them I would ground the water main to the electrical grounding system to equal out the potential in hopes that would take care of the issue. Problem is, I won't know if that does it until either the tank rusts out again or it doesn't. Has anyone else ran across this before?
