K8MHZ
- Electrician
Years ago a friend of mine was getting a house he owned ready to rent out so I was helping him make sure all the electrical stuff worked.
I get to the foyer and there is a row of three switches. The foyer light is on. I switched each switch and the light stayed on. So I went hunting for a switch I missed, found none. When I went back to the foyer, the light was off.
So I flipped the switches until the light came on, flipped the switch off and the light stayed on. I stood there and scratched my head a bit and after about 30 seconds, the light went off. I turned the switch on, the light came back on. When I turned the switch off, the light stayed on for 30 seconds or so and then would turn off.
I asked my friend if there was a timer. He said he didn't know, his dad wired the place up and the light has been doing that as long as he can remember. He said he has never seen a timer, even in the basement.
He asked me if I could just make it work like a normal light. I said sure, not really knowing what I was getting into.
I pulled the switch and when I bypassed it, the light would function normally. No 'delayed off' feature at all. If I put the switch back in, the 'delayed off' feature
came back.
So I just had to play with it for a bit. This was a standard on/off switch.
Then I noticed......
When I flipped the switch on, I could hear the click inside the switch. When I flipped it off, there was no click. Until 30 seconds later. The switch would click and the light would go off.
I put a new switch in and all was well. I took the old switch home to play with it.
Sitting on the bench, not connected to anything, I checked it using a meter. I would flip the switch on, hear the click and see the meter respond. I would flip it off and there would be no click for about 30 seconds. Then the switch would make a click noise and the meter would respond to show an open circuit.
I kept that thing around for a while, but have since lost track of it. It was one of the most unique troubleshooting jobs I have run across.
came back.
