olly
- Berthoud, Colorado
- Master Electrician
I have a customer that has a shed / barn 320' away from the main on the pole. I am changing the main to a 200a 8 CRKT panel with feed through lugs on the bottom. The existing house is on a 100A. So I will put the house on a new 100 amp breaker in the new 200a 8 crkt panel. Here is where the question is. I was going to run 4/0 URD, land it on the feed through at the bottom of the main disconnect, run it 320' and mount another 200a 8 crkt panel on this shed. You and I both know they wont pull over 80a and we also know the wire should be upsized for this voltage drop but I am trying to keep conductor cost down along with labor of installing heavy 350 or something close. What do yall think? Technically this will be to code because 4/0 wire is large enough for a 200a.
