Sparky1981
PE
- Denver, CO
- Electrical/Lighting Engineer
I have a rental property with an issue. I am headed to the property next week to dig in more but wanted to pick your brilliant brains here first. Here is the issue. There are three rooms at play here. The kitchen, connected to a dimmer. The dining room, which is a fan/light connected to a switch, opposite side of the wall from the kitchen dimmer. And a half bath, switched, room directly across the hall from the kitchen. Small space and most likely these are all on the same circuit.
The issue is when the switch to the dining room fan/light is on, just this, the light is fine. When the kitchen light dimmer is at 75%, the dining room lights on the fan begin to flicker. I am talking a hard flicker, more of a strobe. But this stops when the half bath light is turned on.
My question to you is what are possible issues you see? I believe the lamps in the fan/light were changed by another tenant to LED or CFL. I am going to change these to incandescent. Still a bit bizzare they strobe since they are switched and the dimmer is for the kitchen but perhaps there are some harmonics getting to the fan lights when the kitchen is dimmed making the LED in the fan freak out. Any thoughts would be most helpful.
