Installer
- DesMoines, Washington
Where does a Transfer Switch get its Power?
In the diagram below, we are doing work on both the Main Critical Panel (ELPA) and the Main Normal Panel (MDPN).
I'm going to have the Utility come in and shut down the Utility Feed at the Transformer.
I'm also going to lock out the Emergency Generator (EDG)
From the One Line I believe the ATS is powered by through the Normal Panel MDPN.
So when we remove power from that Panel, what gives the ATS the power to switch to Diesel (EDG) ?
Of course it does, but I'm just curious where the power comes from.
The thing here is that we have an ASCO KBC-DCVA-0260S Microprocessor controlled ATS that doesn't have one of those big manual safety handles for Maintenance
that you can open and isolate everything and completely make the Input and Output of the ATS safe. So I have to lock out the EDG to make everything safe
So I'm curious when the ATS loses power, where does the ASCO KBC-DCVA-0260S Microprocessor controlled ATS get its juice form? Will we have a dead microprocessor controller?
When does it become active again? When power is restored at the Utility?
