jeff48356
- Livonia, Michigan
I just failed a rough inspection due to the recessed lights not being Air-tight rated. Apparently there is a new energy code that went into effect on the first of this year, that I was not aware of until just now. I haven't done any work since then that the code would have applied to. All the cans on the main floor are OK because the house has a second floor above them, but the ones on the upper floor need to be changed out with air-tight rated cans. My question is, is there an easier way to make them compliant other than changing them out? Would I be able to simply buy some air-tight cans, remove the gasket around them, and re-apply it to each of the existing cans? Or do they make such gaskets that can be used with non-air-tight cans?
