Sparky_Dee
New User
- Texas
If you have a 4/0 AWG conductor that is connected to a circuit breaker in a 120/208-volt, 3 ph, 4-wire panelboard, how many amps of current can it carry inside the panel?
conductor material would be nice to know too
I don't get the "inside the panel" part of your question. The code will tell you what the ampacity of the conductor is. It will likely be the same inside the panel as in the conduit running to it, short of the conduit having a bunch of other current carrying conductors in it.If you have a 4/0 AWG conductor that is connected to a circuit breaker in a 120/208-volt, 3 ph, 4-wire panelboard, how many amps of current can it carry inside the panel?
