Qwertytfc
- Arvada, Co
I had a situation on some can lights that were flickering. It is fed from a 2 wire without ground home run. When I test the Hr I get 120v hot to neutral and used a pen tester to verify that the black conductor was the hot wire. I then in the junction box for the center fan and the first can light tied all my hot conductors together which fed the switch down on white and back on black. I would read between 30v and 120v from any disconnected neutral coming from cans, receps and unknown cables of constant power back to the known HR neutral even with the switch off(fan is tied to constant power and is switched with a remote). Can someone clarify why im getting between 30 v and 120v testing from outgoing neutrals to the known homerun neutral? I was using an auto ranging digital multimeter. Thanks.
