Knock out filler
Doesn't everyone know you're supposed to use 4" sq covers for large KOs? :cool:
Nothing wrong with that and I almost exclusively do that for anything over 2" as I don't normally stock any plugs larger than 2".
Used a bolt and fender washers occasionally on small holes when I maybe didn't have a plug handy.
Had a couple irrigation control panels this past year that had plastic hole plugs that failed and then mice got into the panel - they really make a mess of things when they have an offseason to do their thing in there. I will not use plastic plugs in those applications anymore and may even replace existing ones when I encounter them. These were factory installed in openings for options that were not used that happened to fail in the incidents I was referring to:rant:
I take it plastic is not a good idea? In so far Raco looks good, hopefully it can hold u to all the abuse a drop ceiling brings.
I like the 3 piece ko plugs. Also will use the hoffman as a lot of what I install is NEMA 4, also Hoffman comes in SS. I kept an assortment of hoffmans on my truck
~R:rotflmao:J~
