McLovitz
- Northern NJ
Electrical novice here but, as a homeowner, I'm stuck between my electrician and town electrical inspector while installing an inground fiberglass pool in your backyard. I came here hoping for an expert view to sort through the disagreement.
In short, we failed our bond wire inspection yesterday as the town said the bond wire has to be 4-6" below grade per code. Per our contractor, we are going to pour 3" or so of concrete on top of the wire (as a bond beam to secure the pool) and then above that, paver stones will sit on the top level that are 2.25" thick (and in between there will be a paver base) so the bond wire will clearly be at least 4-6 inches below the final grade once the final grade is set. However, the town inspector still insists we have to bury the bond wire 4-6" below the dirt before pouring concrete. Our contractor insists this is less safe as the bond wire will be too far below the final grade once we go 4-6" below dirt then add concrete, then paver base, then paver. So he is pushing back but in the meantime our project is held up while they fight over what is code. Again, I'm a novice and I see the 4" to 6" is measured from "subgrade" per the code. I'm not sure what is meant by "subgrade."
Any thoughts are much appreciated.
