nietzj
- St. Paul, Minnesota
- Electrician
210.12 clearly states all 120 v single phase 15-20 amp loads need to be Arc-fault protected in a dwelling. So I have a situation in a Dorm, (Dwelling) and there is a 120 volt fan coil within the room which I have connected to an Arc-Fault breaker. Breaker has tripped many times and I'm planning to install dead-front devices and replace the Arc-fault breaker with a regular breaker. Not a great solution but it's code compliant. Just wondering if the code writers considered this situation. The fan coil is in the ceiling with guarded access for maintenance.
