LibertyEngineering
- Allentown, PA
I understand National Electric Code. Section 210.20(A) which basically says that a circuit breaker for a branch circuit must be rated such that it can handle the noncontinuous load plus 125% of the continuous load. (A continuous load is one where the maximum current is expected to continue for 3 hours or more.) In other words, the breaker needs an extra 25% capacity of the continuous load for headroom.
How does this apply to the breaker in the distribution panel feeding the panelboard with all the branch circuits?
I always assumed that breaker to just be sized based on total load in the panel plus 125% so taking the connected load of all the branch circuits in the panel and adding 125% to come up with the breaker size to feed the panel.
For example, a 100A panelboard fed with a 100A breaker in a distribution panel should not have more than 80A of connected load.
Is this a NEC requirement for sizing this part of the distribution system or just good engineering practice.
Thanks for your response.
