RumRunner
- SCV Ca, USA
- Retired EE
Efficiency of a motor isn't necessarily directly related to the power factor.
Efficiency of a motror is simply the ratio of power in to power out. Low power factor indirectly leads to possible increased losses in the supply lines but doesn't change overall efficiency of the motor itself.
Well, that is a rudimentary knowledge on how inductive loads provide useful work to our benefit.
Low power factor and its effects are more noticeable on the energy distribution sector.
This low power factor increases the non-useable energy that is turned to heat. Heat in distribution systems is the consequence of low power factor.
This heat build up that occurs in the distribution lines increases resistance of conductors and thereby cause voltage drop. This voltage drop propagate to the system being served.
Motors running on LPF also run in elevated temperature. . .a consequence of LPF. ( some modern motor design can compensate for this only to a certain degree. )
This doesn’t save you however from the pitfall of LPF because it (load) draws higher internal current.
Power supply running outside unity PF reduces efficiency of motors connected as mentioned in my previous posts.
