- New Jersey
- Journeyman Electrician (retired)
I guess I don't know exactly what FS is, but many refer to those like you pictured that are typically water resistant to at least some degree. Simple "handybox" or 4x4 with raised covers are also pretty commonly found surface mounted.
I think your post could be interpreted by some that only those weatherproof boxes like you posted a picture of are allowed to not utilize a bonding jumper to the device, may or may not be what you intended though.
Add: my comment wasn't addressing removing screw retaining non metallic washers as much as it was addressing the need to require a wire bonding jumper, or not.
Got it. In my original post I said "FS like boxes" not thinking that FS wasn't common terminology.
You're correct a handy box would be another type of box (not similar to an FS) where removing the washer to provide the bonding would be permitted.
