Busarider29
- Saginaw, MI USA
If I have a 3-phase heater (480 VAC) where its controlled via a contactor, if one of the contacts of the contactor burns shut, will it pop the fuse on one of the other two legs of the heater (all 3 legs are fused)? Using either delta or Wye heater? I don't think it would and I believe that the heating element on the leg where the contact is burned shut will just heat as normal, where the other two won't, but none of the fuses will blow. Confirmation please
