Are there any special requirements for having two service entrance feeders tapped from the same transformer? If an existing utility transformer has two separate SE feeders feeding two lineups located in the same building are there any special requirements outside of 230.90 for SE feeders? Do the tap rules of 240.21(C) apply here?
From what I can tell there are no special requirements for this case other than the standard requirements of 230.90 which would require these feeders only to have overload protection at the SE equipment they feed and be routed outside except for where they enter the building with no specific limitation on length for the outdoor routing?
