I was looking at transfer switches that use 3 pole breakers to switch the neutral on a typical residential service. They mentioned that the neutral will be first to make contact and last to break, otherwise you could get a voltage spike (just like a loose/broken neutral) for a short time period as the breaker opens/closes. I don't know if this is a real or theoretical issue. Also don't know if they just used a typical 3 pole breaker for this or it was some special one where the neutral pole was guaranteed to close first and open last.
