Timer to replace toggle switch?
S'mise
Michigan
I was wondering if a timer is available that's small enough to replace a standard toggle switch for lighting.
I've used decora shaped timers but have never seen a timer that'd fit a toggle plate.
Do they make such a thing?
Thanks.
With electronics getting smaller and smaller, I thought one might be on the market.
I'm sure it is possible, but who wants any kind of display/control interface as small as it would need to be for a toggle switch plate?
Me. But yes, point taken.
Although It could have a rotating toggle to select the time, or just time out after a fixed 8hrs.
That is what we have had for many years with spring wound timers. Most usually had their own plate with time marks on them though. Modern ones have a aux plate with markings that can fit on standard toggle opening or a decora opening though.
Do you have room for a solid state timer ?
He does; he's hoping to avoid having to use a Decora plate.
Well, lookie-lookie at what I found!
Guess that is fine alternative for a spring wound type timer.
I was initially thinking of programmable 24hr - 7 day timers, the user interface would be nearly impossible to use via a toggle switch sized opening.
Thanks Larry. I couldn't find specs, but It looks like it has a wider toggle requiring a special switch plate.
What he said:
It’s just frameless, that just makes it look bigger. Should fit a standard plate.
If you're still unsure, contact the manufacturer or seller. The page I posted has plenty of customer service contact info.
