Alex Verdecia
- Plantation Florida
- Master Electrician
Can someone help!
In this case we have a 12V pool light that you get charge if you touch the light metal casing in the water. even after you turn everything off at the house, I even pull out the FPL meter off the panel you can still fill it. Any suggestions.
all electrical connections are done correctly on the pool equipment.
