Dark Sparky
- USA
- Electrical Engineer
Scope: the USA.
When performing load calculations involving generators, when does one use the (industry standard) 0.8 power factor (pf), and when does one use the load's power factor (let's assume it's 0.9)?
Case in point - if determining the # of generators (500 kW each) required to feed a given load (load is 500 kW or 555 kVA at 0.9 pf), how many generators are needed?
Alternately, if one has a 500 kW/625 kVA genset - will that supply a 500 kW/555 kVA load (with 0.9 pdf)?
Thanks in advance for helping me wrap my head around this.
