Those "nominal" pipe sizes were already established before we started using similar sized ones to pull conductors through.The 'imperial' conduit sizes are 'nominal', meaning that they have some vague historical connection to the number. Something along the lines of 'pipe was specified in terms of its _inner_ diameter, but manufactured to a specific outer diameter. As manufacturing methods (and wall thickness) changed, the _outer_ diameter was held constant but kept the name. (Which makes sense; 1" pipe fittings will mate with 1" pipe, even if they are of different wall thicknesses.)
The 'metric' conduit sizes are also 'nominal', with a different history.
Rather more like names or words in a language than actual measurements. If you trace the 'etymology' back enough you might find a real measurement. If you want some fun look up the history of 'AWG' wire sizes....
Um, no1/2 inch pipe usually has ~1/2 ID, where 1/2 tubing often has ~1/2 OD, but 1/2 electrical raceway is going to have ID that is near 1/2 regardless of what type it is.
I would think using standard fittings with typical sizes is always easier in terms of availability and replacement.The nominal conduit size is really a minimum. What's the complaint with providing more space than the spec?
I wonder whether one can use actual size in a case where the needed area exceeds the table area by a fraction.
I meant for wire fill purposes.I would think using standard fittings with typical sizes is always easier in terms of availability and replacement.
The "~" does not mean "exactly" All the 1/2 inch nominal dimensions you gave were closer to 1/2 than 3/4 though.Um, no
The inside diameter of schedule 40 "half-inch" pipe is 0.62 inches.
The inside diameter of schedule 80 "half-inch" pipe is 0.55 inches.
The inside diameter of schedule 40 PVC conduit is 0.58 inches.
The inside diameter of "half-inch" EMT is 0.7 inches.
Tilde. ~
approximately, or similarity In math.
it’s a not in logic, although I prefer to use an exclamation mark !
I am confused of the metric size of conduits in table 2/chapter 9,
e.g. in table 2, 16 metric vs 1/2", 1/2" approx equals to 13 mm also the outer diameter is approx 21 mm, so what is the meaning of 16 here?
Where does one even find a double tilde?Mathematics uses a double tilde (≈), to mean approximately.
How do you access that?The Character Map on your computer.
