StarCat
Industrial Engineering Tech
- Moab, UT USA
- Imdustrial Engineering Technician - HVACR Electrical and Mechanical Systems
I am looking for simple rules of thumb for basic types of motor loads. As one example, I used 7 SEC. ramp up time for a High inertia Fan load which seems to be ok. I have another load which is a centrifugal pump which is not currently on a VFD, but may be soon. This would be an application that would benefit in this case from a longer ramp up time and would utilize 1-3 PRESET running speeds. Because this pump is started dead headed in several operational modes. Increase on the ramp up time could possibly be balanced with the time it takes the operator to get to the downstream valve and open it. Up to 15 SEC might work, but what would be considered too long? This also would likely be a speed selection which would limit top speed to 40 HZ. The decel times seemingly would be left at default or close for pump duty. Pretty quick I think.
