Hello,
I've had issues with noisy 3 pole 120 volt coil 600 volt ABB Definite Purpose Contactors. When I shut off the power to the Coil and turn back on, it seems an noisy contactor may be quiet and another turns noisy. What could prevent the odd Contactor from buzzing occassionally?
I am planning to clean the surface area with "Deoxit Contact Cleaner" which is more expensive but apparently helps break down oxidation not just clean and blow off grime. I was curious if WD40 Contact Cleaner would do the same job, as it is readily available and just clean the surface with fine emery cloth? ( which I heard leaves residue that may cause pitting)?
Thanks for any feedback!
