- San Francisco Bay Area, CA, USA
- Electrical Engineer
Unless it is a 12 lead motor set up for Part Winding or Wye-Delta starting, it will be a NEMA 9 lead motor connected using one of the diagrams below. The thing is, you will not know if it is a Delta or a Wye wound motor until you see the diagram that came with the motor. If it is small, it's likely Wye wound, but how small is small is something the motor mfr determines when designing it; it's really about economics. General rule of thumb though, at 480V 10HP and under will be Wye wound, 50HP and higher will be Delta wound, anything in between is a craps shoot.
