FaradayFF
 - California
Hi Guys,
Quick question here - can I use a larger cable size compression lug for installations where I'll be using a smaller diameter cable. For example, I need to terminate a #1 cable to 5/8" terminal stud, but the smallest 5/8" compression lug I'm able to find is rated for 350kcmil conductors. Is this a no-no or can this be done?
I'm not sure if the barrel can be compressed "tight" enough to make an acceptable termination.
Thank you,
EE
Thank you,
EE
