I was involved in the design and manufacture of variable speed drives for many years - decades. The only components I know of with a defined operational life were electrolytic capacitors. Their declared life depended on operational conditions. We did some very large drives with hundreds of typically 2200uF 450V capacitors. Some have been in service since 1992 with one set of replacement bucket capacitor banks.Hi
Can someone suggest me the siemens web link , where I can check the life cycle of sinamic drives.
Thanks & BR
I don't greatly disagree with that. It depends on what level you delve into for repairs. Can you get replacement boards? Maybe not. Replacement components? Possibly. In the end, I think it comes down to cost. Is it cheaper to repair or replace?I agree with Besoeker, except that practically speaking, once a high volume manufacturer like Siemens ceases production of a product line and stops buying some of the key components going into the drives, the supply chain dries up and repair parts become unobtainable, so effectively your choices become so limited on what you can expect in terms of reliability and Mean Time To Repair, it ceases to make sense to keep using them. I then put a practicality limit at 10-15 years. Having worked for Siemens, it’s really less than that, maybe 7-10 years. They like to cut and run on older product lines when newer models are released. When I left in 2011 we were selling Master drives, the Sinamics were just being released. It’s virtually impossible to get any repair parts/boards for Master drives already, most people I talk to about it are already scrapping them.
Yes, understood. I mentioned some large variable speed drives that we designed and manufactured. A cement works has has two 2,250kW units (about 3,000 HP) units in operation since 1992. Last night, one had a trip. Turned out to be an SCR on a printed circuit card. A component costing around $1. Cheaper to replace that than the whole drive.............Where I worked just retired two AB 1336 drives installed in 1999, 21 years is a long time for any electronics. But there are still lots of 1336 drives out there, so much that AB wants old drives back to refurbish for legacy customers.
But new drives are generally less expensive and smaller. The 1336 was basically a hand mfg drive, the new powerflexes are less expensive due to manufacturing changes, and offer more communication options
The ones in the cement works | mentioned have been going since 1992. 24/7.The best fans on the market are rated for 88,000 hours at full load, so if a VFD is running 24/7/365 that's the 10 years mentioned.
Clearly they don't make them like they used to. (Although I also wonder how many times the bearings were replaced over the years?)The ones in the cement works | mentioned have been going since 1992. 24/7.
That's 245,000 hours.
Possibly a few times. But it wasn't end of life.Clearly they don't make them like they used to. (Although I also wonder how many times the bearings were replaced over the years?)
