Hello,
I have an 600 volt HVAC that says the maximum Breaker is 40 amps. I have someone that has an good deal on an 600 volt 45 amp Breaker that tells me there should be no problem. The cable can handle the larger Breaker but are there other issues it may cause? I was thinking it is mostly an motor which should be ok with the "next breaker size up"?
Thank you very much for your feedback!
