cjbouchard@bergco.com
cjbouchard
- spokane W.A
Hello Im working a a step-up transformer 120/208 delta to a 277/480 Y Im getting voltage readings all over the place with 3 different meters none of the reading are good In my opinion L1 250v L2 284v L3 284v secondary . 122Vac L1 L2 L3 solid on the primary. The transformer is mounted inside a shipping container on a metal L shaped plate .
Im stumped at the moment But believe something is going On that is not good For the reason it was hooked up to a new machine and it blew the surge protector right out of it Im trying to determine if the voltage indifference is the problem or there was something wrong with the machine and how much voltage indifference is acceptable.
