Are you referring to a Caseta repeater? Not sure what a Caseta receiver is. The repeaters are cord and plug and not designed for hard wire or concealment.Can I bury a casita receiver inside the j-box behind the light so we can put a wall plate transmitter far away? Lutron tech guy said no problem on his end
Are you putting an actuall caseta switch in jbox and connecting to a pico? Or putting a connect bridge in jbox. I would not recommend either one. Can you put switch in a closet then program to pico?
Sent from my SM-G988U using Tapatalk
